Upgrading from Portable V8.x to Portable V9.x
Mr.X
Post by Mr.X »
What's the exact procedure in this case? Portable > Portable
I don't want to lose any profile or any profile settings.
I don't want to lose global settings.
Thanks in advance for your kind reply.
Re: Upgrading from Portable V8.x to Portable V9.x
1. Make a copy of entire V8 folder (i.e. profile settings, ini files, exe, DLL files etc). This is to ensure you have a backup in case of mishaps.
2. Download SyncBackPro V9 No-Install version to a folder of your choice and unzip it over the current files:
http://www.2brightsparks.com/assets/sof ... tup_NI.zip (32-bit)
http://www.2brightsparks.com/assets/sof ... tup_NI.zip (64-bit)
Mr.X
Post by Mr.X »
Thank you @Swapna. It worked.
