Hy everyone.
One question:
I have a profile that it copies a source X from a destination Y. It is posible to delete all folders and files in SOURCE when the execution is correct??
Now, I have it configured with a bat file that executes a command "del", but I'd like to do it with Synbackpro.
Example
NET USE O: \\source
del /F/S/Q O:\*.*
net use O: /delete /Y
Thanks!
Delete SOURCE after profile execution
- Enthusiastic
Re: Delete SOURCE after profile execution
You can configure SyncBackPro profile to move files to destination i.e. to copy file to destination and delete them from source after the copy is success. Please read this forum post for additional details:
viewtopic.php?t=12188
- Enthusiastic
The second link is broken, but,
If the files exist in source and destination, Synbackpro doesn't move the files.
I use Synbackpro to move files, but I need to delete the ENTIRE source when the copy is correct.
Now I can only do it with a bat file. I see an option to delete the source BEFORE passing the data, which doesn't make much sense.
- Enthusiastic
Someone with the same problem?
