These are the pertinent settings in the profile I am trying to use:
Files will be synchronised between Left (Y:\!! FILES\Drive\) and Right (Y:\! SORT 2019\! Drive\).
If the same file has been changed on both Left and Right then the files will be ignored.
Files only on Left are moved to Right.
If a file is only on Right then it is ignored.
At the very least, the third statement is being ignored because I started out with 10 folders on the left, two folders on the right, and finished up with exactly the same, even though the profile states Success. I have refreshed, shift-refreshed, and closed everything down and reopened it from scratch.
Any idea where I should start troubleshooting?
I'm clicking the wrong option somewhere...
