Seperate window showing the "Progress"
- Enthusiastic
Instead of the "progress" being in a column that you cant really see unless you stretch the window across the entire screen, a window on its own below the schedules having the full width of the window would be great, so that you can see and review the progress action in full.
Re: Seperate window showing the "Progress"
You haven't stated the version of SyncBackPro you are using?
Please note that Pro V9 release version (V9.0.8.15) displays the progress bar horizontally at the bottom of the SyncBackPro main-window. So, please upgrade to the latest version and see if it works?
- Enthusiastic
That's cool, I have the latest version though and cant see where the option is to show this, can see in the column only?
- Enthusiastic
Hmm, no reply? I don't believe what you say is not what I'm talking about, although i haven't seen what your talking about. The progress should be seen line by line in a separate window below the profiles, click on a profile and the work done should be available to see and scrollable. Hope that makes sense?
Can you please send a support ticket to [email protected] with screenshot of SyncBackPro main-window showing a running profile for investigation.
