Only run profile if connected to particular network?
adoucette
Post by adoucette »
I have Syncback Pro 9.0.9.14 (x64) and a profile on my laptop to periodically back up my documents folder to a samba share on the network. When I take my laptop away from that network, I get syncback errors because it is trying to run the profile and can't reach the destination drive.
How can I avoid these annoying errors? (browser window pops up with syncback error log for every failure)
I have already checked the box in Modify Profile --> Copy / Delete --> Silently fail if destination cannot be reached through the network
Should I have syncback check for that connection first and only run the profile if that network connection is available? (how?)
Or other?
Ari
Re: Only run profile if connected to particular network?
Please export your profile configuration (select the profile > right click > Export Profile) and send it to [email protected] for assistance.
