I'm using SuncBackPro V9 and cannot locate the check box or whatever that stops a profile from running if it is past it's start time i.e. if there was a holiday on Monday and some profiles were due to run on that day, I don't want them to run on Tuesday when the the syatem is restarted for example.
I know that this facility is available but I cannot locate it.
Sneff
Prevent profile from running if past start time
Re: Prevent profile from running if past start time
I have found the answer myself. Open the particular Profile Setup - When - Edit Schedule - Settings - Last line "Run task as soon as possible after a scheduled start is missed"
and in my case I would untick the box.
Sneff
Sneff
