OneDrive Personal Vault Sync
wheatism
Post by wheatism »
Hi all,
when creating a profile for Onedrive (Personal) sync I can see all the standard Onedrive folders and evrything is ok.
However, no "Personal Vault" folder is visible. Is this Onedrive feature not supported?
SyncBackPro v.9.2.30 64bit/Windows 10 Pro
Re: OneDrive Personal Vault Sync
Post by Kostas »
Unfortunately at the moment the OneDrive Personal Vault is not available via the OneDrive API which means it cannot be accessed by SyncBackPro. If Microsoft extends its API to include the Personal Vault then we will have a look at it and see how to incorporate it in SyncBackPro.
