Profile running of file change after external drive re-connection?
JeffK
Post by JeffK »
I have set up a regular backup (external SSD drive) to do a fast backup of changed data if the computer is idle for 300 seconds. If the drive is installed this works fine. If I have it disconnected I accidentally get a "Scan failure". When I then reconnect the drive the profile does not run. If I recall correctly when I last set up this arrangement on my old laptop (which suddenly broke down and I purchased my current one) the profile would still run if I reconnected the drive and the computer was idle for the 300 seconds.
Am I recalling this correctly or do any forum members have any experience of this. Any help would be appreciated.
Jeff
