I just noticed before a backup that I happened to make manually that SB (v9) ignored a file on syncing two drives. It's a normal .zip file with no special attributes, and was a new file only present on the Source. When I got into "Choose files/directories" the file was unchecked(??) even though the folder should include new files/folders there.
How could this happened? I went through the help page "Most common reasons for files being skipped" but none of them applied, I did not change any of the default compare options.
SOLVED, it was just an unnoticed filter... It would be neat if this window would somehow show why an item is unmarked - either handpicked selection or affected by a wildcard filter (with eg different colors)
Also a better forum engine here, that would enable to mark a thread as "solved".
