I'm looking to automate (Unattended) this functionality; is anyone aware of what combination of settings I can use to meet this goal?
Files only on Left are copied to Right
If a file is only on Right then it is ignored
If the same file has been changed on both Left and Right, then 'copy to Right if Left is larger'
(i.e. Do not copy from Right to Left under any circumstances; the "Left" side should not be changed.)
I am able to do this with a manual Run and manually setting all Copy-to-Left to Skip.
TIA.
Backup only if larger, or force never-copy-to-left
