Versioning database on cloud
markb
Post by markb »
Hello, just a question about the versioning database:
why is it created on the spot instead of storing it on the cloud (or locally)?
On the cloud it slows down considerably the fast backup time.
No chance to make it work without comparing on the spot?
(assuming the backup destination doesn’t get changed of course and only syncback has access)
Re: Versioning database on cloud
Can you send a support ticket to [email protected] with your profile configuration (select the profile > right click > choose Export Profile from pop-up menu) for assistance?
Do not post (nor link to) profile on this open forum.
