Hello, I have been testing with copies to a FTPS server, with the V9 version it works perfectly with the "Eldos" and "Weonlydo" engines, however with the "SmartFTP" engine it fails and gives an error that I have not been able to solve.
Exactly the same error that gives me in the V8 version, either SE or PRO, I can't get it to work...
Is it possible to change the FTP engine in the v8 version?
I understand that it would not be normal to have to change all the versions I have sold and distributed to V9 for this reason
FTPS Backups fail in v8
Re: FTPS Backups fail in v8
Eldos FTP engine is supported only in V9.
Pro V8 supports, WeOnlyDo and SmartFTP engines when backing-up files to SFTP server.
Sorry, but I bought several licenses of Syncback PRO because they supported FTPS and now that I have to use it it turns out that it doesn't support it, in the specifications it clearly says that it supports FTPS.
Please solve the problem or offer me an upgrade to V9, I bought several licenses that should work, I do not understand or understand the answer.
Greetings
Greetings
SyncBackPro V8 supports file backup to FTP, FTPS and SFTP servers. Can you please submit a support ticket to [email protected] with your profile configuration and logs for investigation.
