Archive file base on last accessed date
I have been using the last modified date to archive old files. However, there are files that I do not modify but I need to access (read) them. Is there any way I can setup/configure SyncBackPro to archive files that has not been access for, say more than 1 month?
Re: Archive file base on last accessed date
Sorry not supported.
Thanks for your prompt reply.
Hopefully, in future, that could be implemented like AWS S3 object life cycle management, to move file that are less frequently access to cheaper storage.
