Hi there, looking for a solution while syncing to Google Drive File Stream.
Currently SyncbackPro syncs files between my source drive and my google drive (File Stream) which is then sent to cloud. As I make changes, the sync works great. Deleted files are removed, new files are copied etc. But, since all the files are sent to the cloud, I want to delete local files at times.
In the Decisions/Files settings, I have gone to the folders tab -- > What to do if file exists in Google Drive but not on Left --> Do nothing/ignore
With this instance, any files within that directory on the Left that are deleted are then deleted in drive, but the directory itself remains. I want the entire directory and all files to remain untouched in my Google Drive when the directory can't be found on the left.
Is there a setting in which I can delete a directory on the left and then skip looking at the the full directory on the right in my drive?
Directory Delete on Left But remain intact on Right
