Antimalware Service Executable
morice
Advanced
Advanced
Post by morice »
Today when trying to use an existing backup profile to a network drive i ran into an issue. It had worked fine a couple months ago, but now it was unable to complete scanning the destination (or even start). When i looked into windows' task manager i noticed that the Antimalware Service Executable process was showing plenty of network activity, but nothing was happening. Eventually SyncBack stopped saying the scan could not complete. Then I discovered that the profile completes just fine when i disable integrity check on destination. The network drive is connected to a Raspberry Pi with OMV if that matters.
Turns out Integrity Check is not really useful for me here anyway though. I just wanted to check if the files copied correctly, but it doesn't really work that way. Any way i can manually do a 'Verify' run after the fact?
