Delete folder contents before backup.
[email protected]
Post by [email protected] »
Hi Guys
I backup drive images to an external drive, but the drive images are now too big unless I manually delete the folder contents first, is there a way that Syncback Pro can delete the files in a folder prior to backup ?
Alan
morice
Advanced
Advanced
Re: Delete folder contents before backup.
Post by morice »
Yes there is that option in the profile setup's Copy/Delete section under the Advanced tab.
But beware it deletes absolutely everything in the Destination folder, so make sure there is nothing else in there.
[email protected]
Hi
Firstly, thanks for the reply.
The only 'Delete' function I have is 'Delete in OneDrive' & 'Delete in Source', but I want to 'Delete in Destination'
Alan
morice
Advanced
Advanced
Post by morice »
If it mentions OneDrive then your destination is set to OneDrive, if this comes as a surprise then i would warn against using the option altogether.
