NEW RELEASE SyncBackPro V9.5.5.0 (10th March 2021)
laurent
Post by laurent »
Post by laurent » Sat Mar 13, 2021 10:32 pm
The links are not working :roll: for the 1st time to me !?
https://forum.2brightsparks.com/bb/viewtopic.php?f=15&t=14003
1 post • Page 1 of 1
Post by mickyj » Wed Aug 28, 2019 3:29 am
SyncBackPro V9.5.5.0 (10th March 2021) is now available for download:
http://www.2brightsparks.com/assets/sof ... _Setup.exe (32-bit)
http://www.2brightsparks.com/assets/sof ... _Setup.exe (64-bit)
Digitally signed by 2BrightSparks Pte Ltd
The No Install version can be downloaded here. Simply unzip the files into a folder of your choice:
http://www.2brightsparks.com/assets/sof ... tup_NI.zip (32-bit)
http://www.2brightsparks.com/assets/sof ... tup_NI.zip (64-bit)
laurent
Re: NEW RELEASE SyncBackPro V9.5.5.0 (10th March 2021)
Post by laurent »
This is Chrome browser that does not allow clicking on the EXE/ZIP links silently... #-o
You may have better luck on getting this fixed if you do as this info suggests:
laurent
Post by laurent »
Hi
It's not a need for 2BrightSparks to provide technical support on SyncBackPro, or a bug
It'a about the links in this forum itself to download the EXE files...
The click with Chrome browser does nothing in this forum
This is the only Web site I know that have trouble with that !?
Regards
Post by Kostas »
Thanks for bringing this up, we've fixed the issue.
Regards,
laurent
Post by laurent »
You're welcome :)
