SyncBack Monitor Android
Roaster
Post by Roaster »
Hi!
Using the latest SyncBackPro 9.x on Windows and latest SyncBack Monitor on Android, I wonder why the monitor does not detect the Windows application.
The tablet where the monitor app is running, is in the same network as my Windows PC. Of course passwords are set and equal, according to the help document in Android help.
My network has a subnet mask 255.255.0.0, don't know of this is of any relevance and I can ping the Windows PC from the tablet with appropriate ping apps. Nevertheless both instances do not connect.
Any hints available what to additionally check to let the monitor app find my Windows installation?
zekeblue
Re: SyncBack Monitor Android
Post by zekeblue »
I have the same issue. I am working with support and will submit logs to see if they can troubleshoot.
Roaster
Post by Roaster »
Thanks for this information!
