Recently I've made some changes to my PC setup where I now only have a desktop and a laptop. The desktop is my main system and has about 50TB of hard drive space. Thus it is the system where I store ALL of my backups. SyncbackPro is one of my main backup applications. One of the recent changes I've made to my desktop is to put the system into sleep mode after 20 minutes of inactivity. This has presented a problem for SyncbackPro on my laptop, it does now wake up the desktop when it runs in the early hours, between 0500-0700. After a bit more testing I will possibly narrow the runtime gap.
I looked at the help and searched the forum but don't see a solution. I did not see any solution in the help file, I did find a possible method with a Google search but before I go down this path I wanted to ensure a better solution was not available.
wakeup SyncBackPro V10.1.8.0 (Mbit)
				jgt
- Knowledgeable
				jgt
- Knowledgeable
Re: wakeup SyncBackPro V10.1.8.0 (Mbit)
Should beThis has presented a problem for SyncbackPro on my laptop, it does now wake up the desktop when it runs in the early hours, between 0500-0700. After a bit more testing I will possibly narrow the runtime gap.
This has presented a problem for SyncbackPro on my laptop, it does not wake up the desktop when it runs in the early hours, between 0500-0700. After a bit more testing I will possibly narrow the runtime gap.
