I "found" SyncBackPro this morning and would like to know if and how I can achieve the following:
when a file is saved to a local folder it needs to be immediately uploaded to an FTP location
This means SynBackPro is actively watching this folder
after the upload this file needs to be moved to a "processed" folder
This way I always keep a local copy of the file
is this possible with SyncBackPro?
Move local file after upload
wilkob
Re: Move local file after upload
Nobody?
Is what I am trying to achieve not possible?
You should be able to do what you want with a couple of profiles using When, Changes.
See:
https://www.2brightsparks.com/syncback/ ... hanges.htm
See:
