Hi, I need help!
I've used SBP v8 successfully with my DropBox account for a couple of years, backing up various files to DB. I've recently got a new PC and have exported/imported my SBP backup profiles from my old PC, however now when I run a backup, SBP says that the connection is being throttled by the source. It says this every time now, so I decided to try a few things to fix it.
The next problem I hit is that when I modify a profile and click the yellow folder next to the Dropbox destination, it says "Connect to the Dropbox server?" and when I click Yes then SBP locks up for over a minute, then says "Unable to connect: Connection Closed Gracefully".
SBP is Authorised with my DB. In fact I've removed Cloud from my profiles, gone to my cloud accounts and hit Remove, logged into my DB account and gone to Connected Apps, and clicked Disconnect, and I've done a Delete DB on one of the profiles as a test.
Then I've started from scratch, creating a new profile and authorising with DB again (it reappears in Connected Apps in my DB account), but same problem when I click the Destination folder icon in the profile, when it asks me to "Connect to the Dropbox server?" it locks up for over a minute and says unable to connect.
Any ideas?
Can't connect to Dropbox
Dave300
Re: Can't connect to Dropbox
Fixed it! Went to SBP Preferences > Options > Expert, and changed Default communication encryption at the bottom to TLS V1.1.
Connected right away, and it backs up with no throttling. Go me!
