I have a profile (mirror) that isn't creating a log file.
The only hint to what has changed is that I upgraded to version 10. This profile was created from scratch. I've also recreated it. I have 3 other profiles (backup) that are logging normally. I've upgraded and installed Syncback countless times and created hundreds of profiles over the last decade and i've never had this issue. I looked to see if logging was enabled, it is. In all my time using Syncback i've never disabled logging. I didn't know it was an option.
Is there is another location/configuration somewhere i'm overlooking?
Log File Not Created
Re: Log File Not Created
Try looking at the logging options by modifing your profile, switch to Expert mode, go to the Log settings page and change the settings on what to log or not log.
