I like to use ransomware detection. However, my problem is that the file names for the comparison files only allow fixed file paths.
The drive names of external USB drives change often. So a comparison with a file on the backup drive does not work anymore.
It is planned to offer the possibility to use variables (%LABEL=DRIVENAME%) in the file path of the comparison files.
When entering source and destination of a backup it works fine.
Thanks for the suggestion but unfortunately due to the technical aspects of this feature and its implementation it's not an easy change to make, at least for now.
