Where is the setting to tick to use the basic sync instead of intelligent sync?
in this article https://www.2brightsparks.com/syncback/help/synchronize.htm
It says it is advisable to use intelligent sync and intelligent sync is used by default, but it does not say how to use the basic sync if you want to.
How to use basic sync instead of intelligent sync?
synchelp
Re: How to use basic sync instead of intelligent sync?
Any synchronization profile created using SyncBackPro or SyncBackSE will be an Intelligent Synchronization profile. There is no option in SyncBackPro/SE to convert an Intelligent Sync profile type to a Basic Sync profile type.
If you wish to use a Basic Sync profile then create a Synchronize profile in SyncBackFree.
