Latest version does not remember full screen
Sasa
- Enthusiastic
Latest V10.2.99.0 remembers window position and size, but not full screen.
Re: Latest version does not remember full screen
Thanks for bringing this to our attention. We released a new SyncBackPro V10 beta version which should fix the problem. You can download and install the beta from here:
https://www.2brightsparks.com/downloads-beta.html
Sasa
- Enthusiastic
I assume this means it was fixed?
Sasa
- Enthusiastic
Yes and no!
Screen first opens in last state size and then maximizes. This occurs on all screens when opening - e.g. preview screen before sync.
Screens should open directly in their wanted state - it looks like an unwanted animation.
Due to technical reasons that's the only way we can force it to maximize, to ensure that there are no problems related to the screen's DPI.
Sasa
- Enthusiastic
I don't understand that, because SBP is the ONLY app, that behaves like this. Take office-apps (word, excel,..), browsers (edge, breave, chrome,...), diropus, adobe apps (acrobat, ps, is, au,...) and so on - they all don't show this behviour and open directly maximized on all dpi (I use misc. monitors/pc's/tablets with different dpi and always maximized apps).
Sorry but that's how it works at the moment. It may not be perfect but it does what it's supposed to do.
Sasa
- Enthusiastic
But is this not just a simple standard GUI-command that comes with the OS? I can live with it, but it should not be something we have to think/talk about in 2023!
