Integrity check to fail the profile run
poisonborz
I'd like the integrity check function to fail the profile run. If I see it right, the only way to do this is to create a script that runs syncback in cli with the -integcheck option, and then check the value task scheduler for the last result. Is this right, or would there be an easier way?
