Scheduled profiles failed on network
BiemmeUff
Post by BiemmeUff »
Hello, with the latest version of synckback pro i am having some issue with scheduled profiles to save data from servers to nas.
The error is " cant connect to network destination" , if i run manually the profile there is no problem, checking the connection to the nas from the profile setting with username and password is ok. I am using synckback on servers since 2008 and never faced this problem, only from the last month i am having trouble with scheduled profiles, Windows server 2022 SynckBack PRO 10 and 11, Qnap and Synology nas with new and old firmware.
Thanks in advance for any suggestion
dorisguiterrez
Re: Scheduled profiles failed on network
Post by dorisguiterrez »
Hello
I suggest you can try reducing the schedule interval temporarily (like every 5 mins) to rule out any timing issues. The scheduled task may be trying to run at an inopportune time when the NAS is unavailable briefly.
mreizinho
Post by mreizinho »
Dear BiemmeUff,
I'm experiencing the same issue. Did you find out a way to solve this that you can share? Thank you very much
