I'd like to know if it's possible to export also the global settings and other configurations for SyncBackPro, as it seems that it's only possible to export/backup only the profiles.
Thanks.
Export global settings and other configurations for SyncBackPro
nicos18
MikeTaku
- Experienced
Re: Export global settings and other configurations for SyncBackPro
Yes, you can back up SyncBackPro's global settings, not just profiles. Just copy the `SyncBackPro.ini` file from the app data folder and, if needed, export scheduled tasks from the Windows Task Scheduler.
nicos18
MikeTaku
- Experienced
