In Nextcloud copy the old version of the modified files to the trash
Vexarmor
Post by Vexarmor »
Hello experts,
A question about using PC backup to Nextcloud
In backup mode, instead of overwriting a modified file by replacing it with the new one, SyncbackPro copies the old version of the modified files to the trash and copies the new version.
The Nextcloud trash therefore grows with each backup.
For a file modified every day, this means lots of files from old versions in the trash.
Backing up to a Google Drive or to a network SSD does not cause this problem.
Is there a solution to avoid this?
Thank you in advance for your help
Best regards,
