Hello folks
At the end of each year I save a complete snapshot of all data, which I otherwise update weekly in a mirrored data store. Over the years, this adds up to a lot. I would like to delete the files of the snapshot of year x-1 whose file attributes have not changed compared to the snapshot of year x. Is it possible to carry out this task with SyncBack operators? If yes, please give me a short howto.
Hartelijk dank jongens
Herbert
Is there a 'delete on source if equal to destination' - or viceversa?
				hhr
				hhr
Re: Is there a 'delete on source if equal to destination' - or viceversa?
... got a hint, that I'm tampering with an old version. Indeed SB11 fits that needs. SysOp may send this post to dev0.
				liame
Yes, you can achieve this with SyncBack by using the "Delete" option in conjunction with file comparison settings. You’ll want to configure a profile that checks for attribute changes and set it to delete files in the previous snapshot that match the current one.
