I use a batch file to make a backup.
Well SyncBackPro seems to generate an exit code and it is code 0 for if the backup is good.
Which command line do I use to check that the backup went well and if it went wrong that it displays an error message on the screen?
What does that look like?
use of exit code in a batch script
Storm-_-
- Enthusiastic
Storm-_-
- Enthusiastic
Re: use of exit code in a batch script
I've already found it.
SyncBack apparently puts the exit code in the variable %errorlevel% (Windows batch file).
