Editing variables
KSMike
Editing variables
Post by KSMike »
I apologize for the dumb question, but I was fairly sure it was possible to do this but don't see where.
How can I edit the contents of variables (in this case the path in %SYNCBACKBACKUPFOLDER%)?
Dave Wilkins
Post by Dave Wilkins »
Hi
You can't change the value that a built-in Variable evaluates to, sorry. But you can replace the one you mentioned with a hard-coded path (or even a Windows Environment Variable - or a mixture of all three) of your choice
KSMike
Post by KSMike »
Thanks.
Zodler
Re: Editing variables
Post by Zodler »
Where does %SYNCBACKBACKUPFOLDER% point to?
Because I run the no install version and option of putting new profiles to the same directory as program but
my backups all go to
C:\Users\.......\AppData\Local\2BrightSparks\SyncBackPro
Post by Kostas »
%SYNCBACKBACKUPFOLDER% is pointing at the current user's (the one who is running the app) private application data folder where usually apps will store application data related to the user. This is regardless if the user started SyncBack from an internal storage (local disk) or external storage (e.g. a non-install version was running from a USB device).
If you want to store the profile backups elsewhere then you can always change the folder under Preferences -> Options > Expert > Back all profiles.. path.
Zodler
Post by Zodler »
Thanks. Just a suggestion, the no-install zip version should be truly portable and store all data where it was unzipped regardless where it is.
Post by Kostas »
We'll look into this for the coming release.
