Are global profile changes possible?
markg2
Post by markg2 »
If there's a particular setting that I wish to change on ALL or a selected group of my profiles, instead of modifying each profile separately, is there a way to globally do so all profiles at a clip?
Mark
Re: Are global profile changes possible?
Any particular version (number)? ;)
This can be important - for example, although this thread basically has the answer, its description of where settings are (how to access them) may have changed since then. However, the underlying concepts are much the same, and a rummage through the Help should assist if you need it (now you know what to look for). There's a section in the Help on Shared Settings, for example.
:roll: - that link got truncated (lost the last digit) somehow - it should be
http://www.2brightsparks.com/bb/viewtopic.php?t=8221
markg2
Post by markg2 »
Sorry for the delay--apparently auto notify not set.
Version 7.6.8.0 (en)
