Connect to iPAD
Amyco
Connect to iPAD
Post by Amyco »
I use SyncBackSE V7.6.8.0. The program works well in my use on Win 10.
But I just see a small problem: I connect my iPad to my PC via a USB connection. Windows Explorer sees the iPad and I can access the images it contains.
I wanted to use SyncBackSE to save these images in a directory on my PC, but unfortunately I can not describe the iPad as a data source.
What solution can I use to do this?
Thank you for your reply.
Re: Connect to iPAD
Post by Kostas »
You may try creating a SyncBackSE profile that uses Media Transfer Protocol as the source, then select your device from the available MTP devices (make sure the device is plugged in on the USB) and see if you can navigate through its contents.
