Drag and drop folder paths
Syncy
Post by Syncy »
Hi
I haven't used SyncBack in a while but last week I needed to sync quite a bit of data to a new PC. I've installed the latest version of SyncBack but I've found I cant drag and drop a folder into the Source and Destination fields. I'm sure I used to be able to do this?
Re: Drag and drop folder paths
Post by mickyj »
Hi, sorry, we had to remove this. The edit control that accepted dropped files and folders had some strange issues related to resizing. We couldn't resolve it so unfortunately had to remove them. You can still drag & drop onto the main window, but no longer directly into edit boxes.
Syncy
Post by Syncy »
Thanks - I was sure it used to be there :)
