system backup
[email protected]
system backup
Post by [email protected] »
Hi, I search a solution to make systeme backup of Windows 7/8/10 with SynchBack.
Does anyone have an idéa?
Re: system backup
Post by Kostas »
Here is a (very) old topic on the subject: http://www.2brightsparks.com/bb/viewtopic.php?t=970
Please note that SyncBack is not designed to (and cannot) make an exact copy of a system drive. SyncBack is a backup utility designed to backup files-based data that are created by the user (that is, files created by you and do not backup system or applications). Cloning or imaging drives are not supported, nor will be supported in the future.
