SyncBackSE V7.6.45.0 (8th November 2016) released
Post by mickyj »
SyncBackSE V7.6.45.0 (8th November 2016) is now available for download:
Digitally signed by 2BrightSparks Pte Ltd
Changes made in this version
Updated: Windows XP is no longer officially supported
Updated: When using screen reader the auto-collapse option in profile config window is not enabled
Updated: Warning text in profile config window now a tab stop to help with screen readers
Updated: New pop-up menu and shortcut keys to select source (Ctrl-F2) and destination (Ctrl-F3) versions from Differences window
Fixed: On Vista and newer, if profile was set to run on logout, shutdown or restart, and it was Windows shutdown aborted, then SyncBack did not close properly
Fixed: French help file may not display
Fixed: The attributes and dates are now from the target file when compressing symbolic link files
