Compression error
mveba1
Compression error
Post by mveba1 »
Unable to find this error message in support?
12:14:57 PM \MVBA-GoldmineSQLData.zip Failed to copy from Source : Unable to compress file: D:\Network\Backups\CopySQLFiles\MVBA-GoldmineSQLData.zip
The file could not be saved in the archive (0): Cannot write to zip file. (507)
Re: Compression error
Post by Kostas »
This error occurs when there is not enough free disk space on the disk where the Zip file will be stored (the destination). It can also occur when there is a network connection problem while trying to save the Zip file, or the destination is inaccessible.
(From: http://support.2brightsparks.com/knowle ... p-file-507)
mveba1
Post by mveba1 »
Thanks. I realize that but not sure why all of a sudden files are not being overwritten or deleted. Not even sure what to look at or where to make changes.
