Profile start when shutting down
Computerdienst
Post by Computerdienst »
Dear all,
I recently installed a new Windows 10 Laptop for one of my customers. I also installed the newest version of SyncBack SE. I created a profile / backup-task and set it to run when the user is shutting down his machine.
This worked perfectly with Windows 7, but Windows 10 seems to have some problems.
This things can happen:
1. The backup starts but suddenly I'm back at the desktop.
2. The backup runs correctly but when I boot the laptop again autostart isn't working (OneDrive, SyncBack etc. not visible in tray)
Are there any known issues? And maybe any solutions? The obvious one - reinstall - has already been done. Also changing the KillTask Time Out in the registry.
Re: Profile start when shutting down
I just tested with SyncBackSE V7.6.50.0, but I couldn’t reproduce your issue. Note that we have recently fixed an issue when running a profile on Windows shutdown/logoff. Please refer to the release note of V7.6.45.0:
https://www.2brightsparks.com/syncback/changes.html
Therefore, if you are not using the latest version of SE, I would suggest you to upgrade and test the profile run to see if it resolves your problem:
Computerdienst
Hi swapna,
It really seems to be exact the bug I'm facing BUT I installed SyncBack about 2 weeks ago. I already should have the version with this bug fixed. However I will install the newest one, but I don't think this will help then.
Computerdienst
Hi Swapna,
I just checked with the customer. He already has version 7.6.50 installed. Any suggestions? :)
Please submit a support zip of the profile in-question for further investigation. Full instructions to create and submit a support zip are given here:
Computerdienst
Hi swapna,
Really strange. I switched to english and debug, and now it works like a flaw... I really have no idea why?
I keep you updated if the problem shows up again.
