How to copy a profile
humblepie
Post by humblepie »
I want to make a copy of a profile because most of its parameters will be the same in my new copy. However, when I make a copy of the profile and try to rename it or modify it, it appears the profile is something of a link to the original profile. Any changes are reflected in both!! That's not what I'm after. What am I missing here?
Thanks!
humblepie
Re: How to copy a profile
Post by humblepie »
For instance if I rename the copied profile, the original profile is also renamed. I simply want my copy of the original profile to act as a new and separate profile but with all the same settings, at least to start off with and any changes are only reflected in this new profile.
humblepie
Post by humblepie »
Here's something I did between last post and now:
1) Made a backup copy of all "backup profiles" from the appdata/local folder for SyncbackSE
2) Uninstalled SyncbackSE using an uninstaller that removed local settings/profiles from my PC (Advanced Uninstaller Pro from download.cnet.com)
3) Re-installed SyncbackSE
4) Imported the last known good copy of my profiles from the backup created earlier. (I was careful to import inside groups profiles before importing the group itself as discussed in various articles here concerning such. Thus, imported inner-most profiles and worked my way up the food chain.)
Copy of a profile seems to work again.
