I have a couple of profiles set on a schedule to run daily. I just noticed they aren't running and when I looked at the schedule, I saw this note under status:
"The requested operation requires elevation (0x800702E4)"
Any idea what this means?
Windows 10 Pro x64.
syncback SE 7.6.50.0 schedules aren't running
Re: syncback SE 7.6.50.0 schedules aren't running
Please read the below KB article for the solution:
http://support.2brightsparks.com/knowle ... ion-0x8007
Thanks Kostas. Per that link, it appears I fixed the problem already. I'll find out for sure in the morning.
Yep. The issue is resolved.
I found that checkbox earlier after looking at the help file in the program. I noticed that checkbox was unchecked in your example, so I unchecked mine to follow the example. Then your later response with the link proved that I made a lucky (but uninformed) choice.
