Sorry if this was raised elsewhere. I looked around and couldn't find anything.
I am running Windows 10. I normally have the icon in the notification are set to display so it always shows in the notification area.
For awhile I've been experiencing a problem when updating to a new release. After the update I end up with no icon displaying in the notification area. If I go into taskbar properties I see two entries for SyncbackSE. One is OFF and one is ON. See the attachment.
The problem is that the one that is ON doesn't work (nothing is showing up in the notification area). It seems to be related to the previous release or something. The one that is OFF seems to be the one for the current release. In any case, if I turn the one that is OFF to ON, then the icon appears in the notification error. Sometimes if I then go back into the settings, there is only one entry for SyncbackSE.
Any idea what is going on?
Bill
notification icon in notification area not showing
- Advanced
Re: notification icon in notification area not showing
We have answered via your parallel support ticket.
