One of my SyncbackSE jobs is to back up several websites via FTP. While it does a great job of backing up files, I usually get an error per server because it cannot access one of the webserver log files (it is open and locked on the webserver). I have no control of what files are locked on the server, other than at least one of the log files is usually locked when the server is running. (I wish the FTP server simply wouldn't list locked files that can't be accessed, but it does, and I can't change its behavior.) I would like to backup as many of the log files as possible so that we have a solid history, but it's barely worth the annoyance of reviewing the SyncbackSE errors every day, just to verify it's the same log file error on every server. Note that the log file names are randomly created by the server, so I can't just elect to exclude a certain known filename. Also, many different log files are created on a daily basis (and they are not locked), and I still want to back them up, so I have to enable backing up of new files within that directory.
Is there any way to make SyncbackSE consider file copy errors within a certain directory to be considered only warnings and not errors? I realize the grave perils of such a setting being universal, but I'm thinking with certain limitations, it could be quite useful. Perhaps it could be used in combination with other conditions such as "ignore the first x errors within directory \wwwroot\logs\yyyyyyyy".
SyncbackSE already has so many options that I figured I could find a workable solution, but I have been unable so far. Perhaps I'm just not creative enough or looking deep enough.
Does anyone else have this problem or know a solution? Thanks in advance!
Locked files via FTP
Re: Locked files via FTP
The only situation in which a file copy error can be recorded as warning is - when a file (usually a temporary file) cannot be copied because it has been deleted (or moved) by something else before it could be copied to the destination, which can be configured under Modify > Log settings page. But other file copy errors (e.g. caused by a locked files) are recorded as errors, this is due to safety reasons and to prevent the occurrence of any risky or unforeseen situations in the future.
However, I will pass your request to the relevant department for their review.
