Windows 10 Ransomware Protection Conflict
[email protected]
Post by [email protected] »
I have just upgraded to Windows 10 1709 the Fall creators update. This version includes a new facility in Windows Defender to set certain folders to be protected against ransomware. I have added Syncback.exe to the list of excluded applications but when I try and run a backup I get a failure with this error message
Ransomware Detection: The hash value of the file (D:\Tim's documents\O0507P4A.rtf) could not be calculated: Cannot open file "\\?\D:\Tim's documents\O0507P4A.rtf". The system cannot find the file specified
Re: Windows 10 Ransomware Protection Conflict
The error message:
means the Ransomware detection file set under:
Preferences menu > Options > Expert tab is not available or accessible. Hence SyncBack failed to calculate and compare the hash value and stopped the profile run with that error. Please refer to this article for more details on Ransomware detection and how it works:
https://www.2brightsparks.com/resources ... cback.html
Can you please check if the file ‘O0507P4A.rtf’ is present in the “D:\Tim's documents\” folder? If not, you may have to click on 'Clear' button under:
to remove the ransomware detection option. Then choose an existing file or create a new ransomware detection file to enable the detection again.
