Filter help
LFNfan
Filter help
Post by LFNfan »
Hi
I am trying to define filters for my backup profiles, and struggling. Any help would be much appreciated.
I have the following folder profiles and structures, Movies and TV:
Source \\Server\Movies\
Destination J:\
Folder structure in Movies is:
\101 Dalmations\101 Dalmations.mkv
etc etc
\A Space Odyssey\A Space Odyssey.mkv
etc etc
\Whats New Pussycat\Whats New Pussycat.mkv
In Movies I have two profiles, one to back up folders starting 1 - N, and one to back up folders starting O - Z. I am running into the limitation of the File and Folder selection which is that any new movies also need their boxes checking manually. I'd much prefer to succeed with a DOS Expression Filter. What I have is the following pairs:
\1*\
\1*\* These work. But I can't bring myself to replicate the pair for 0-9 and then again for A - N. Then again for O - Z.
\[1-5]*\
\[1-5]*\* These don't work, even though the Help file suggests that they do. Any advice would be much appreciated. I am clearly missing something...
\\d*\
\\d*\* These don't work either. I thought that \d was the most elegant way of expressing a digit. But no joy. Perhaps because "\" is confused for a child folder starting with "d"?
Folder structure in TV is:
\A Bit Of Fry And Laurie\Season 1\A Bit Of Fry And LaurieS01E01.mkv
\A Bit Of Fry And Laurie\Season 1\A Bit Of Fry And LaurieS01E02.mkv
\A Bit Of Fry And Laurie\Season 2\A Bit Of Fry And LaurieS02E01.mkv
etc
\Yes Minister\Season 1\Yes Minister S01E01.mkv
\Yes Minister\Season 1\Yes Minister S01E02.mkv
etc
Again, I have two profiles, one to back up A - N, and the other O - Z. I have tried to use the same filters as above. The single character filters work, and seem to catch all the season sub-folders and files. The [A-N] variants do not work.
Many thanks in advance for any pointers.
Paul
LFNfan
Re: Filter help
Post by LFNfan »
OK, I figured this one out. I had not expanded and changed the 'More Options' dialogue box in the filter. It was set to use the default 'DOS expressions' which I belatedly realised can't resolve [0-9] or \d etc etc. I switched to 'Regular Expressions' and [0-9] [a-n] etc works.
For reference, at the moment my regex is:
\\[0-9].*\\
\\[0-9].*\\.*
\\[A-N].*\\
\\[O-Z].*\\.*
etc
There is a very handy regex tester website which I used to work this out.
Hurrah for Syncback.
