SyncBack and Win10 UAC on every run
borisvar
Post by borisvar »
Every time I run SyncBackSE (licensed copy, 8.5.26.0 64-bit) on Windows 10 (properly updated), the UAC is triggered and pops up the dialog.
What should I do that I am not required to confirm it every time? Beside the point I am quite certain than SyncBack is NOT making changes to OS with my backups.
Re: SyncBack and Win10 UAC on every run
Hi, see this Knowledge Base article
Note that the wording* of the UAC prompt is Microsoft's choice, and more accurately would state that the elevated privileges (see KB) being requested potentially give more scope for changes to the system than a program running non-elevated would have. It doesn't necessarily mean SB is asking to make any changes right now, but the MS prompt wording can give that impression.
PS the KB article refers to different wording* of the UAC prompt, which (IIRC) is how it prompted in Vista. The wording (as you probably know already) is 'Do you want to allow...' in Windows 10
