Simple definition - Unattended Run cannot prompt for action?
What does this mean? It is a frequent warning I get for 2 or 3 different files.
Re: Simple definition - Unattended Run cannot prompt for action?
Please submit a support zip (with debug logs) of the profile run to [email protected] for investigation.
Thanks for the help. Logs submitted now.
