I have 2 PCs connected with an ethernet cable. I have given both a fixed IP and I can browse the files on one from the other. However, when I try to run SyncBack SE, it gives me "the username or password is incorrect". This with an open explorer window browsing the files right next to it.
The program was working fine previously, I just reinstalled PC#2 (new HD). The ethernet connection shows as "unidentified network" and is set as a public network. I can view files on each PC if I share the folders.
Can you help ?
Wrong Username or Password ???
Re: Wrong Username or Password ???
So I quit SyncBackSE, restarted it and went to modify my sync profiles (new user directory name on reformatted PC) and it asked for username and password access to the second PC, after that it worked
