Been using Syncback SE for a while and am having a problem with the file comparison after backing up .pst files as it logs the run as a failure 8 times out of 10. I have tried setting a delayed run to ensure all file locks are cleared but I still keep getting the warning "Failed to copy from Source : The copy is not identical to the original. The original file may have been modified after it was copied" which is really annoying as I run the backup unattended in the background every few hours.
The file is stored on a windows home server and the backup location is on a desktop (client) PC.
Any ideas how I can stop the failure due to this error?
Problems with Comparing Files After Backup
