Problem with network credentials
lockon
Post by lockon »
I use SynBack to backup to a Synology Diskstation. The share where the backup is destined is R/O to the 'admin' user (same username as the domain controller but Synology is not on the domain). The synology account with R/W is 'backup'. When I configure the network credentials in the SynBack profile and click 'Test Connection' I get "Success!". I also have selected the 'Use the supplied username ...' option under Network|Advanced.
However, when the scheduled backup runs, I get the error "Access is denied" in the log... If I change the 'admin' account to R/W on the Synology and everything completes as expected... seems like SyncBack is ignoring the 'Use the supplied username ..." option?
Sunil
Re: Problem with network credentials
Can you please export and send your profile configuration (select the profile > right click > Export Profile) to [email protected] for investigation?
